Kehennig72
Feb 01, 2025Aspirant
Nighthawk app
My RAXE300 stopped working with Nighthawk app, I’ve tried powering cycling but nothing works.
I can access the router via the internet browser but nothing works the app. Any suggestions?
is anywhere access enabled in the app?
Are you using any vpn's or anything like that on the device running the app?What actual error do you get?
- Kehennig72AspirantYes anywhere access is enabled, no vpns.
The app worked before but I believe there was an update and since it won’t login. I don’t get any errors. I try to login after I enter my password it thinks for a minute then returns to login.- plemansGuru - Experienced User
what modem/gateway is the router connected to?
