solomani
Feb 19, 2017Aspirant
Parental Control - Curfew by device?
Hi all,
Is it possible to setup a per device schedule? For example, I want device-X to have no internet access after a certain a time each day. As best I can tell I can only do this across the whole network which isn't very useful. Happy to be corrected.
Thanks.
solomani wrote:
Thanks. But the pdf only goes to page 127 :) Looking at the scheduling section it doesn't really help. Is there another section I should be checking?
Somehow my cut/paste went bad, and I linked you to the R6300 manual by mistake. I've corrected that link - the page numbers were correct in my earlier post.
FWIW, you can find the manuals, data sheets, and firmware by entering "Netgear D6400 support" into google, and clicking on the Netgear link - normally at the top of the search page.
What router model do you have (and what firmware is it running)?
Many Netgear routers will let you set up a schedule like this, but not all.
- solomaniAspirant
Hiya,
DS6400 with V1.0.0.56_1.0.56.
solomani wrote:
Hiya,
I am guessing you meant the D6400. The instructions on page 130-131 of the manual show how to do it: http://www.downloads.netgear.com/files/GDC/D6400/D6400_UM_EN.pdf?cid=wmt_netgear_organic
You'd use "all" for the service. Also set up the device so it has a reserved IP address (otherwise the rule won't kick in). If this is a device with both ethernet and wifi you will need two rules (and two reservations) - one for ethernet and one for the wifi connection.
- solomaniAspirantHi StephenB this worked perfectly thanks for your help.
