morgnstern
Nov 17, 2016Aspirant
Parental controls for individual devices only works on IOS
Parental controls are working when set as a default policy and I am able to change the policies to recieve different results. I would like to set my default policy as restrictive and manage specific ...
morgnstern
Nov 22, 2016Aspirant
Dexter,
1. Yes
2. My Android (Samsung S7) Android version 6.0.1, App version 2.4.38
3. R8000, Firmware version V1.0.3.4
From my phone, via the network map, I cannot change my filtering level by device. The option is no longer there. When it was, it didn't let me, I just got an error "failed to set parental controls". Other devices it would, such as my Ipad. Also from the phone, when I go to parental controls, it prompts me to log in to the router, then it prompts me to log into OpenDNS, and I cannot get past that login prompt. From my PC I can, on my ipad I can. From my Ipad I can change the filtering level of my ipad, but not my phone. From my Ipad, I can logon to my bypass account, from my PC I cannot. My phone doesn't get far enough into parental controls to even have the option.
On a side note, I noticed I can set filtering at the "Opendns.com" Cisco Umbrella site by managing my personal network and I can also set it at netgear.opendns.com. It seems like the Cisco Umbrella site takes presidence. Should one be used and not the other?
Thank you for looking into this.
Chris
DexterJB
Nov 22, 2016NETGEAR Moderator
Hi morgnstern,
Thank you for providing the details.
We recommend using the filtering settings set via the NETGEAR Genie app/program which is in sync with the one in netgear.opendns.com. Your settings via the Cisco site may be conflicting/affecting how the NETGEAR filter functions.
Dexter
Community Team
- ParplyMay 15, 2017Star
If you have a netgear LPC account you can also login to the umbrella site and see/edit some of your settings. If Netgear LPC are not compatible with having settings edited on the umbrella site then Netgear should have worked with OpenDNS to disable the controls. At least make it more prominent than the banner that get presented on the umbrella site. And lets be honest whilst this might complicate things the issues with not being able to set LPS filtering etc. are being widely reported and are independent of such potential complications.
