Mikemilleriu's avatar
Mikemilleriu
Follower
Apr 04, 2018
Pause internet blocked all internet
Last night I paused internet on one device using the Netgear Genie app on my phone.  It completely blocked all internet to all devices, including the phone I did it on.  Since it will not connect to the wifi, I cannot log in to change the settings back or use the wifi for anything.  How do I reverse this action?  Will doing a factory reset on the router clear this?
  • Hi Mikemilleriu,
    Welcome to the community!
    Yes, resetting the router will reverse that as well as clear all your settings. Instead, you can try accessing the router UI and disable the Access Control feature. Here is the link to access the router UI and go to Advanced > Security > Access Control.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Mikemilleriu,
    I would like to follow up and check if you are still experiencing the issue.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Mikemilleriu,
    Dexter
    Community Team
