Sarav
Aug 07, 2016Aspirant
R6220 - Wifi Analytics wont get connected
Hi,
The router R6220 has been connected and I was able to access internet.
The WIFI Analytics feature placed within Netgear Genie Androd App says its Not Connected and iam not able to use any of the feature in that option.
I tried installing the Netgear WIFI Analytics as stand alone app, still its not getting connected. Tried with both the bands.
Rest of features in Netgear Genie Androd App works good and it shows the established connections correctly.
Please advise.
Thanks,
Sarav
- DexterJBNETGEAR Moderator
Hi Sarav,
1. What is the firmware version of the router?
2. What version of NETGEAR Genie do you have installed?
3. Do you have it installed on a wireless device?
4. Have you tried using another device (wireless capable computer, smartphone, tablet)?
5. Are you getting an error message? If yes, what is the error message?
6. Please provide a screenshot if possible.
Dexter
Community Team
- SaravAspirant
R6220 V1.1.0.34
App V2.4.34
Yes In Android mobile v 6.0
Tried in another Android mobile v 5.1.
It works well.
No errors. It says not connected. Though the wifi status is connected and I am able to access internet.Does this app run on marshmallow Android 6.0?
6. Please provide a screenshot if possible. - SaravAspirant
Screenshot attached.
- SaravAspirantHi,
My mobile model is Lenovo K4 Note.
Thanks.
