PSIU
Feb 17, 2018Guide
R7000 after firmware upgrade, Bedtime function in Circle doesn’t function properly anymore.
I have just updated my Netgear R7000 firmware to V1.0.9.26_10.2.31. I have also enabled the Circle(parental guidance) on my Netgear router with bedtime function turned for my kid. After the firmware ...
michaelkenward
Feb 18, 2018Guru - Experienced User
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
PSIU
Feb 18, 2018Guide
michaelkenwardwrote:Did you reset the router to factory settings after the firmware flash?
Thank you, Michael. In that case, I cannot do a backup and restore on the current setting right?
- michaelkenwardFeb 18, 2018Guru - Experienced User
You can try making a backup. But that could bring back whatever the problem was.
Reset. See if it works when you restore the thing. If not, reset it again and don't restore.
- PSIUFeb 21, 2018Guide
michaelkenwardwrote:You can try making a backup. But that could bring back whatever the problem was.
Thanks Michael for your advice. At the end, I only needed to reset on the parental control setting on my router by switching it off and switching it back on again. I guess I got lucky and didn't have to do a factory reset but I did have to do the parental setup over again though.
