Brummybloke
Sep 12, 2017Aspirant
R7000 netgear app and bt tv issues
I have bt tv lan connected by a bt ac1900 wifi extender. Bt hub 6 for internet connected lan to r7000 providing the wifi. When using the Netgear app to turn kids internet off it then messed up inter...
DexterJB
Sep 19, 2017NETGEAR Moderator
Hi Brummybloke,
1. What is the firmware version of the R7000?
2. Is the R7000 setup in AP mode or in router mode?
3. Is the extender extending the signal from the BT Hub or from the R7000?
4. Is the BT TV box connected to the BT Hub or to the R7000?
5. Are you using the pause Internet feature on the Genie app?
Dexter
Community Team
- BrummyblokeSep 19, 2017AspirantHi thanks for replying
1. Firmware VersionV1.0.9.6_1.2.19
2. R7000 is connected to the bt hub via Ethernet cable in router mode.
3. Bt extender is extending r7000 signal there is no bt hub wifi signal it's turned to modem only.
4. Bt tv box has no wifi it is connected via Ethernet to the bt extender.
5. Yes pausing devices from genie - DexterJBSep 20, 2017NETGEAR Moderator
Hi Brummybloke,
1. Does the issue persist if you have the XBOX's connected to the R7000's WiFi?
2. Does the issue persist if you have the BT TV box wired to the R7000?
3. Does the issue persist when you pause the Internet on the devices connected to the R7000?
4. When you say "reset", are you powering down the router and powering it back on or are you doing a factory reset?
Dexter
Community Team
- BrummyblokeSep 20, 2017Aspirant1. Does the issue persist if you have the XBOX's connected to the R7000's WiFi?
The Xboxes don't teach wifi on the r7000 which is why they go through the extender.
The bt box can't be wired to the r7000 as the bt tv box is in my bedroom while the r7000 is in the living room with the bt hub.
No just on the extender
I'm resetting the router via the net genie.
Thanks again - DexterJBSep 21, 2017NETGEAR Moderator
