hightech
Feb 05, 2016Follower
R7000 Nighthawk - Internet connection keeps dropping.
I have the R7000 router and it has been working well for some time. Lately I find that I no longer have Internet connectivity via wired or wireless devices. I would log in to the router, and see that Internet is marked as disconnected. After logging out, I would turn off the router, wait a min and start it back up and then I would be connected again.
I am using a Cable Internet service with Rogers (in Canada) so there is no login info needed to access it.
Has anyone else had any issues with their Internet connectivity via Cable Internet and can suggest somethings to check. I can't recall the firmware version I hae but it was updated within the last month.
Thanks
- DexterJBNETGEAR Moderator
Hi @hightech,
1. Have you checked if the connection straight from the modem is stable?
2. Have you tried changing the cable that is connecting the modem to the router?
3. Please check the firmware version of the router.
4. Have you tried resetting the router?
Dexter
Community Team
- HaneyEdwAspirant
after latest firmware Auto update and re checked that it is the latest version my internet speed its erratic and goes from 21mbs to 65mgs when checked. yes I tried it direct from the modem yes I checked the firmware version yes I changed the ethernet cable yes I reset the router how can I go back to the previous firmware it worked fine until then ?
ISP Charter Cable R7000 Nighthawk Netgear It has been working fine til now very fast very reliable.
Hi @HaneyEdw,
You can manually update the router's firmware then reset and reconfigure the settings. You may refer to the links below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665Regards,
Dexter
Community Team
I'm having the same problem and it's very frustrating, what ended up working for you?
Hi @mostafa113,
1. What is the model number and firmware version of your router?
2. Have you tried resetting the router and/or reflashing the firmware?
3. Is the connection from the modem stable?
Dexter
Community Team
- gmkws77Aspirant
Having same issues i keep dropping connections? I cant keep two of my printers longer that 30 min. and phone are speratic anlog with other devices.
7-12 month old.
R7000 Nighthawk
Hi @gmkws77,
1. What is the firmware version of the router?
2. Does the issue persist on both bands (2.4GHz and 5GHz)?
3. Are wired devices also affected?
5. Have you tried changing the wireless channel?
6. How are the printers connected to the network (wired or wireless - please provide model number/s if possible)?
Dexter
Community Team
