MikeLorena
Nov 12, 2017Tutor
R7000, Printer not being found in Selection list
We have a NightHawk R7000. our HP laptop, Win10, my printer shows in the NETGEAR USB Control Center but not when I go to print (Word, Excel, PDF, etc.) Any thoughts? Lorea
> [...] my printer shows in the NETGEAR USB Control Center but not when
Did you install your new network printer on the Windows system?
Settings > Devices > Printers & Scanners > : Add a printer or scanner- michaelkenwardGuru - Experienced User
Can you print with the device connected to a USB port on the PC?
I ask because the same thing came up here recently:
Re: WNDR4300V2 Router recognizes the HP printer bu... - NETGEAR Communities
If the printer won't work on a PC, it won't work on a router.
- Yes, it works fine... It actually works on 2 other HP laptops, just not mine. thx for the help. Lorena
- CChrisAspirant
I'm having the same issue along with my Nest losing wireless connectivity.
I do use access control which i turned off with no difference. What I have noticed though is under access control those two devices (Printer/Nest) don't have an IP address. I have assigned a static address to it and that doesn't work either.
I have upgraded to the latest firmware and completed a factory reset, manually setting it up and no change. Rebooting the router allowes it to connect for a short time. Wired/Wireless(w/SSID name) connections have no issues.
