fury88
Mar 14, 2017Star
R8000 no longer connects remotely with Genie app after latest firmware
The Genie app was finally working the way it was supposed with pausing connections, etc but then I went an upgraded to the latest firmware and its hosed up Genie. It shows two routers now, one with a...
DexterJB
Mar 16, 2017NETGEAR Moderator
Hi fury88,
1. We recommend doing a factory reset after updating the router's firmware.
2. If the issue persists, you can try to unregister the router then go through the setup for remote login again.
Dexter
Community team
fury88
Mar 18, 2017Star
Part 2: Re-register fail
