fury88
Mar 14, 2017Star
R8000 no longer connects remotely with Genie app after latest firmware
The Genie app was finally working the way it was supposed with pausing connections, etc but then I went an upgraded to the latest firmware and its hosed up Genie. It shows two routers now, one with a...
ChadB72
Jul 06, 2017Initiate
Should work, may work... but it does not. I think you've missunderstood the issue. No one is having a problem updating or accessing via Ethernet. It's that the Genia app DOES NOT work with the latest firmware.
DexterJB
Jul 10, 2017NETGEAR Moderator
Hi all,
There is no update from engineering yet. Rest assured, this is being worked on.
Dexter
Community Team
- Capster13Jul 17, 2017Guide
Is there any solution to this yet? I can no longer use the destop application or the iphone/ipad applications. I can only log onto the router via the webpage.
