agoetz5201
Jan 06, 2017Aspirant
R8500 - Unable to register router for remote access in Genie app
Unable to successfully register my R8500 router with Genie remote access.
I get the prompt that my router is unregistered but when I try I get a unsuccessful error message telling me to try again later.
I have been trying for weeks... On both WIndows & Mac I get the same unsuccessful message.
The Netgear documentation states it can be done on iOS but nothing appears after login in the list to register.
I had no issues registering the R8500 or RN212 with ReadyCLOUD.
Which leads me to believe there is an issue with the Netgear Genie App.
**I am in network when when trying to register and the device has been factory reset before.
I have been the one and only owner of this router.
I had stopped using it for a while but the bugs seem to be resolved with the WIFI so I am trying to utilize it again.
Using the same email address I used when I previously registered it with.
- Sadman65Aspirant
My Nighthawk R8500 wont setup in remote access with the genie app. It sayswhen trying to enable it
ENABLE Failed "incorrect request format, try again"
Any ideas
- DexterJBNETGEAR Moderator
Hi all,
The case is currently being worked on. We will provide an update once available.
Dexter
Community Team
- AndrewZukovskyAspirantHopefully it's soon cause I'm about to return it with a sledge hammer imprint in the top of it.
- agoetz5201Aspirant
Still broken months later...
Same error message "enable failed" "server error"
Saw the Alexa integration and thought I would check it out the remote access function again.
As a matter of fact no cloud functions work any longer.
Now connecting the R8500 to ReadyCloud keeps failing...
I had to factory reset my device because of firmware v1.0.2.100 seems to have broken port aggregation with my ReadyNas
Since then I cannot connect the router to ReadyCloud again.
If I had to take a wild guess I would think that the R8500 is only allowed to register once.
And factory resetting the device is messing up my ablity to gain remote access again.
This is only reasonable explanation for the constant issue trying to connect to cloud services..
