Deb318's avatar
Deb318
Tutor
Jun 22, 2017
Remote access
How come I can setup remote access from my desktop but I can't through the app. Keeps saying internal error.
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Deb318,
    1. What is the model number and firmware version of the router?
    2. What device are you using (Android, iOS)?
    3. Are you referring to the remote login feature of the NETGEAR Genie app?
    4. Please try using another device (Android, iOS).
    Dexter
    Community Team
    • Deb318's avatar
      Deb318
      Tutor
      Model# R7000 Version: V1.0.8.34  Apple Iphone6 and Yes having trouble with the App. and I have tried other devices.
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Deb318,
      1. Have you tried uninstalling and re-installing the app/s?
      2. Have you tried resetting the device?
      Dexter
      Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Deb318,
      I have sent you a message. Please check your inbox.
      Dexter
      Community Team
