Sgeorges
Jul 07, 2017Aspirant
Remote Genie for D7800 not working (unable to register)
My device is Netgear D7800 Modem/Router. (firmware:V1.0.1.20)
I read through this forum and found it should support remote access thru genie. But I have trouble with enabling the remote access from genie.
I was successfully using Remote access with my previous R8000but but recently switched to D7800 for NBN.
Spent a lot of time and followed setup procedure but couldn't register it.
In step 10, getting an error message "the registration process failed"
I also done following:
1. Resetting the device.
2. Uninstalling and re-installing genie.(in phone & computer)
3. Tried previous versions of firmware / genie.
4. Tried from computer/ and from different android phones/tabs.
Please help. Thanks.
- DexterJBNETGEAR Moderator
- SgeorgesAspirant
Hi Dexter,
Thanks for your message.
Surprisingly it started working now once I tried from another Android phone again.
All good ):
- vipsinAspirant
Unable to turn ON remote access from Genie app. India Technical support is pathetic, just novice guys. Getting error " NO remote access" the genie cloud server connection failed. Try again.
- UriahSefoInitiateI'm having the exact same problem. Please help
