GarrettMoore's avatar
GarrettMoore
Follower
Jan 01, 2019
Router has security questions that I didn’t make
I recently moved into a new home and purchased an AC2400. The internet installer hooked up the router while I was at work. Everything has worked fine but i was trying to link the nighthawk app to the router and the admin / password login isn’t working. I haven’t changed it from the default settings. So I went to reset the password and it gave me two security questions that I’ve never seen and didn’t setup. I can’t reset the password because I don’t know the answers. So I can’t login to my router settings.
  • schumaku's avatar
    schumaku
    These routers show some random (or the first) password recovery questions - regardless if ever set-up or not.
    If the router was set-up by a third party ... asking there would be an idea.
    If you have all details on how to configure the Internet connection (in case there is some encapsulation and/or authentication required) you might want to do a factory reset https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
  • michaelkenward's avatar
    michaelkenward
    There is a bug in some devices in Netgear's implementation of password recovery. You can get locked into a close loop.
    If password recovery is enabled, but you have not set the answers to the questions, it keeps sending you back to the beginning of the process because you can't answer the questions.
    If the standard factory password (password) does not work, then you will have to factory reset the thing to get back to that. Then either disable password recovery (check the manual for your device) or provide some answers to those questions.
    I doubt if they will have changed the password without telling you.
    What is the modem that sits in front of the router? That could cause the behaviour that you see.
