guyguy
Nov 13, 2016Apprentice
Time Schedule and Parental Controls
I am trying out the Nighthawk router and I am comparing its features to Linksys and Asus routers. The router has the latest firmware version. I have a few questions about using the Nighthawk router. I am, more less, confused about some of the features such as time scheduling and blocking sites. Also, I don't understand the purpose of OpenDNS if I can block most sites on the router itself. I am sure that OpenDNS does a better job at blocking sites and categories.
1. How do I block a site such as Facebook on individual device? I don't want to block it from other family members. I have tried both OpenDNS and blocking the site on the router itself from preventing both an iPod and Macbook from accessing Facebook. Both the iPod and laptop let Facebook come up. I have tried to block Youtube on the router and OpenDNS with the same result. I can, still, access the site on my iPod and laptop.
2. How do I set a time schedule on individual devices? I don't want to turn off or disable the wireless to go off at a specific time, I just want to block a device from accessing the internet at specific times like 8pm to 9am.
3. Do I use the Netgear Genie to access the router from outside my home? I like using my work computer to login to my home router to change settings and so on.
I like the Nighthawk router but I need to work through some of these issues such as time scheduling and being able to block sites to individual devices. Perhaps, someone can offer some suggestion on what I am doing wrong and explain some things.
- etorgesonAspirant
Hello Dexter. I know I am late to the party here (and my Nighthawk R7000 router is not even in th dropdown menu so maybe this is an obsoleter thread) but I am writing to check up on whether or not Netgear was ever able to update the parent controls so that after assigning a fixed IP address to a device one could set a schedule for blocking internet use that allowed for multiple time periods of blocking in the same day, and differentiated between days of the week. The last I read on this forum only a single time frame was allowed, and this applied to a select number of days or to all days. That is rather prehistoric.
Eli
- DexterJBNETGEAR Moderator
Hi etorgeson,
Welcome to the community!
You may look into the Circle feature of the R7000 instead. The links below may help in giving an overview.
http://www.netgear.com/landings/circle/
https://support.meetcircle.com/hc/en-us/sections/115000372251
https://kb.netgear.com/000038873/
Dexter
Community Team
- bob1057Aspirant
that would be great if i didnt already own the device. I spent alot of money to redo my entire home network, firewall, ap, and 5 managed switiches just have have it downgraded. If i buy anything again, it wont be netgear.
why cant the parent controls work when the router is off and it just acts as an ap? or put the same parent controls in your firewall code?
- storm1985Prodigy
1. No you cant block apps through LPC. It can only filter HTTP/HTTPs service.
2. To set a time schedule per device;
a. LAN IP reservation - so the IP wont change and blocking services always works
b. Block services - where you configure the service and the IP to be filtered (if you want to completely block that device IP set Service to "ANY" or all services)
c. Schedule - the timeframe you want to set3. 2 options
Remote Genie - where you use the NETGEAR Genie -KB guide here
Remote Management - HTTPs access using WAN IP or dynamic DNS -KB guide hereHope this helps u :)
- guyguyApprentice
Thanks for the response. I was able to block sites and set a time schedule on the Linksys and Asus router. Doing this task was very simple and straightforward. To followup with your answers.
1) I am not looking to block apps on the router. That would be a great feature to have but most home routers don't support it. I am looking to block www.facebook.com or www.netflix.com PER device. I want to block sites without affecting other devices. For example, I want to block www.facebook.com or www.youtube.com so that an iPod or computer doesn't have access to those sites. I don't want Mary to have access to those sites on her iPod or laptop.
2) If Mary's iPod or laptop has an IP of 192.168.0.123, I would static that number on the router and set the time schedule to whatever I want. For example, I want to give Mary from 2pm to 8pm EVERYDAY on her laptop internet access. Next, I want turn OFF the internet access at 8pm to 2pm the following day.
Again, I was able to block sites PER device without affecting any other device in the house. Also, I was able to set a time schedule PER device on both Linksys and Asus routers. It was very easy to do it on those routers and I am looking for the same easy method on the Netgear router.
Hi guyguy,
1. You can use the per device filtering feature on the NETGEAR Genie app/program and set the filtering level to "High" or "Custom" on the devices you would want Facebook and YouTube to be filtered on. You can check the link below.
http://kb.netgear.com/app/answers/detail/a_id/29913
2. As for setting a schedule for Internet access on specific device/s, you can follow storm1985's advice of setting up Address Reservation for the devices then block all services on a set schedule. You can check the links below.
http://kb.netgear.com/app/answers/detail/a_id/24091
http://kb.netgear.com/app/answers/detail/a_id/24055
http://kb.netgear.com/app/answers/detail/a_id/24054
Dexter
Community Team
