rl032952
Feb 02, 2017Aspirant
where can i find a resource cd for n750(wndr4300)
need a resource cd for used n750 router wndr4300....any adeas? router is working but noe effeciently
thanks
I don't know what's on the CD but it should not have anything that would affect the performance of the router. The router can be fully managed through a web browser.
- thenoAspirant
What you will do with CD? If it is not working effeciently than configure it. How CD can help you?
- rl032952Aspirant
i dont have access to any "advanced" settings currently just basic
You don't say which version of the router you have, but the manual here might help:
WNDR4300v2 | Product | Support | NETGEAR
If you don't want to use the browser interface – the best way to do these things – then the Netgear Genie might help.
