Oldbag
Aug 11, 2026Follower
WiFi randomly drops on Apple devices
I just installed the rs600 wifi router on Sunday using the nighthawk app. Apple iPhone and IPad devices were randomly losing wifi but after turning off the devices turning off and on the wifi it wou...
Aug 12, 2026Guru - Experienced User
What iOS versions are on the Apple devices?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Is IPv6 Enabled or disabled?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz and 69 on 6Ghz.
Set Mixed Mode WPA2/WPA3.
https://kb.netgear.com/980/How-do-I-log-in-to-my-NETGEAR-home-router
Oldbag wrote:I just installed the rs600 wifi router on Sunday using the nighthawk app. Apple iPhone and IPad devices were randomly losing wifi but after turning off the devices turning off and on the wifi it would spin and show something about weak security. Then eventually after turning it off then on a few times it would appear without the weak security message. I restarted my modem, then restarted the router and updated the firmware. It stayed ok for about 4 hours and then it went back to the drops and the weird weak security message. I used to see that on my old router so I’m wondering is there something either on the ipad or iPhone I need to set or is there a setting I need to adjust on the nighthawk app?
Anyone run in to this? I called support and they told me my devices need to settle in to the new router. I always thought on or off. Not some random issue where it works and then doesn’t.
