sscaltri
Mar 03, 2026Initiate
WiFi strength on Nighthawk App
I no longer see the wifi strength. I see the connected devices but not the strength. The wifi bands would be darkened. Now they are all light gray. Happens on both phone and iPad.
What model NG router do you have?
- sscaltriInitiate
RS700S
What model iphone and pad do you have?
Is Smart Connect enabled on the RS router?
Might submit a bug report thru the app for this item:
How do I submit a bug report or logs from the Nighthawk or Orbi app? | NETGEAR Communities
