Hansie020
Sep 27, 2022Guide
Black screen after powerup
After powering up my Meural Canvas II, the logo appears on the screen and then the screen turns black. Factory reset did not help. Are there any other options to try
Any help would be highly appreciated.
- KevinLiTNETGEAR Moderator
Hello Hansie020,
Welcome to the NETGEAR Community!
Are you able to access your Meural Canvas II when the screen is black from your Meural app?
Best,
Kevin
Community Team
- Thanks for your reply
No, the app says the screen is offline.- KevinLiTNETGEAR Moderator
Hello Hansie020,
Thank you for your post!
Try these steps to get your Meural Canvas II up and running:
- Unplug your Meural Canvas II
- Then hold the reset button
- Now plug in your Meural Canvas II
- Then wait five seconds then release the reset button
Let me know the outcome of this solution as soon as possible!!
Best,
Kevin
Community Team
- waipangAspirant
Could you let me know if you resolved the issue? I am having the same problem.
- Andy1889AspirantMy device was within 2 year warranty to Netgear eventually replaced it. Took several calls with support teams to try things, none of which worked so replaced it.
