Ak-Lex
Sep 29, 2024Apprentice
Canvas Says Offline
Hello My canvas is not coming online, I am connected to the network, however upon checking on the computer is says status offline. The app on the phone will not sync. I makes the connection to m...
- Oct 18, 2024
Hello Meural Community,
We are aware of the issue with the Meural server that is causing the Canvas I and Canvas II to appear offline on the Meural app and my.meural.com. Our Engineering team is diligently toward a solution to resolve this issue.We value your patronage and appreciate your patience!
Best,
Kevin
Community Team
DrSharon
Oct 05, 2024Guide
I have an old Canvas and a much newer one. Both canvasses are connected to wifi with good signal. The app on my phone and laptop have just started saying that the older canvas is offline but the newer canvas remains online. The Orbi modem app shows that both canvases are connected to wifi with strong signal. I have tried re-booting the modem. I have tried disconnecting the canvas from wifi and reconnecting. Still the app won't connect to the canvas. i have tried clearing all connections and setting up new wifi. Still the app won't connect to the canvas. How do I get it to reconnect? Thanks
Oct 07, 2024Guru - Experienced User
- nicolasjeneOct 07, 2024Aspirant
My Meural MC227 has the following problem: the serverstatus always says "offline" and it is not possible to connect using the app to the device. But the device gets a proper IP address and can be pinged. Anything I can do for fixing this issue?
- FURRYe38Oct 07, 2024Guru - Experienced User
NG seem to be aware of it and working on it?
You'll need to make contact with NG support and let them know if what your seeing and wait for them to get things corrected.
Good Luck.- Kimberley_MOct 08, 2024Star
Mine somehow came back online on Monday (10/7). Was able to send some new images over to the Canvas. Now tonight (10/8) it is Offline again.
Any update Netgear???
Meural MC227
