Ak-Lex
Sep 29, 2024Apprentice
Canvas Says Offline
Hello My canvas is not coming online, I am connected to the network, however upon checking on the computer is says status offline. The app on the phone will not sync. I makes the connection to m...
- Oct 18, 2024
Hello Meural Community,
We are aware of the issue with the Meural server that is causing the Canvas I and Canvas II to appear offline on the Meural app and my.meural.com. Our Engineering team is diligently toward a solution to resolve this issue.We value your patronage and appreciate your patience!
Best,
Kevin
Community Team
Oct 07, 2024Guru - Experienced User
nicolasjene
Oct 07, 2024Aspirant
My Meural MC227 has the following problem: the serverstatus always says "offline" and it is not possible to connect using the app to the device. But the device gets a proper IP address and can be pinged. Anything I can do for fixing this issue?
- FURRYe38Oct 07, 2024Guru - Experienced User
NG seem to be aware of it and working on it?
You'll need to make contact with NG support and let them know if what your seeing and wait for them to get things corrected.
Good Luck.- Kimberley_MOct 08, 2024Star
Mine somehow came back online on Monday (10/7). Was able to send some new images over to the Canvas. Now tonight (10/8) it is Offline again.
Any update Netgear???
Meural MC227
- FURRYe38Oct 08, 2024Guru - Experienced User
NG is aware of this and is working on a fix. Not time frame on final fix. So please be patient.
If you feel you need more help and information, please make contact with NG support.
Thank you.
