absen7e's avatar
absen7e
Tutor
Mar 01, 2022
I can't register my Meural, and support will do nothing to help
I purchased a Meural secondhard. Apparently that's my "mistake" for not researching it in the first place? Unlike most products in the world, these Meruals are serial locked to the person that registered them first.
I have proof of purchase. I am now the owner. Support said they "escalated" my case to get the registration transferred, and that's the last i've heard from them. The last e-mail reply was Feb. 8th. I've called. I let my phone sit on hold for over an hour. No one ever came. There are no more e-mail replies.
How can y'alls support be this bad? What can I do to use this thing?
  • absen7e's avatar
    absen7e
    Mar 02, 2022
    EDIT: I just saw the update.
    @ChristineT Thanks so much for the help!
    I never expected to have a warrenty with it. So hopefully I can manage to get it working now. Unfortunately the "reset" button is broken off it. So.. There's that. One thing at a time. I'll consider this thread resolved and start a new one if I have further issues.
    Thanks again.
    • absen7e's avatar
      absen7e
      Tutor
      Oh gotcha. Thanks for the response.
      I assume actual support doesn't scour these forums?
      This experience has taught me to not buy netgear products. So something positive has come of it.
      • plemans's avatar
        There are the occasional mods on here but not actual support.
        maybe DarrenM or ChristineT can help.
  • ChristineT's avatar
    ChristineT
    NETGEAR Employee Retired
    Hello absen7e ,
    Thank you for posting your concern. We are looking into your case as of this writing. It appears that it has been escalated to a higher tier support for review. We'll reach out to that team to request an update. It's proven to be a bit challenging for customers who purchase pre-owned NETGEAR products. While we are checking with our internal teams, do you have any way of contacting the original owner and asking them to unregister the product through the MyNETGEAR.com support portal? This would be the cleanest and easiest way to resolve this issue.
    Thank you for your patience,
    Christine
    • plemans's avatar
      they'd go to
      my.meural.netgear . com
      click on their profile in upper right----->canvas's---->remove canvas from account.
      its not in their my.netgear . com profile.
    • absen7e's avatar
      absen7e
      Tutor
      Thanks again.
