thegeob's avatar
thegeob
Follower
Sep 27, 2026
Meural iOS Update is broken
Hi,
The newest iOS Meural update is supposed to be including bug fixes, however it seems it has managed to break everything instead!
  1. The  'Canvas' icon now takes me to one of my three Meurals, where it keep saying it is sleeping (it is not) or when it decides it is not sleeping, the brightness and sleep (moon) controls do not do anything. It tries to refresh (Syncing your Canvas) but nothing happens.
  2. After 10 seconds for 'Syncing your Canvas' for everything you do, the 'On Now' Playlist keeps showing 'Try Again' above the works, which again doesn't do anything
  3. The three dots ... icon on top right, now shows only a Gear icon when pressed (no Text) which is the Settings of the current Canvas, but the list of other Canvases on the network is now nowhere to be found, so I cannot view any of the other ones.
And yes I have tried un-installing and re-downloading the app, apart from Logging in for 3 seconds (could see the Playlists) and throwing me back to the login screen 4 times before it decided to finally log me in, there is no change.
Please fix.
BRgds
  • FURRYe38's avatar
    Something to make contact with NG support about. All that is beyond forum help.
  • Seconding this. Please fix the app, the most recent update was an absolute disaster.
