Ajai82
Dec 07, 2021Aspirant
200 mbps to 100mbps MR60 night hawk ax1600
I recently bought MR60 nighthawk Ax1600 with one satellitee, upgraded from TPlink archer C6 . My internet provider speed is 250 Mbps. my old router hit about 200 mbps in my mobile and laptop but now with nighthawk i get only 100 mbps...pls help with
Are you testing over the 2.4ghz or the 5ghz?
2.4ghz is a much slower network than 5ghz.
And the MR systems do band steering so its not something you can just "choose" to be on the 5ghz.
- Ajai82Aspiranti tested with 5 ghz
what wired speed do you get from the router?
What speeds do you get over 2.4ghz?
What modem is it connected to?
Have you checked its internet connection statistics to see if its connecting at gigabit speeds?
How do I display Internet port statistics on my Nighthawk router? | Answer | NETGEAR Support
- bairstowpopeInitiate
With the Netgear EAX15 Wi-Fi 6 Mesh Extender ($129.99), all you have to do is plug it into a wall outlet and configure it with a mobile app to get wall-to-wall Wi-Fi 6 connectivity.
