MAPowers
Feb 17, 2021Follower
Airplay over the Nighthawk mesh 6 system
Is there any plans to fix the issue of not being able to use airplay with or should I be shopping for a new router system. Would like to be able to use airplay to cast to my TV. If there is no pla...
Crcamacho
Jun 30, 2021Aspirant
I have the same issue. My Nighthawk can not connect through airplay. When the company fix this problem.
Christian_R
Jul 07, 2021NETGEAR Employee Retired
Hello Crcamacho,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
- darwiniandudeJul 08, 2021TutorThis still isn’t fixed? Glad I returned mine! Ridiculous. People own iPhones you know. And Apple TV’s and HomePods and other things. All network traffic should be allowed by default on a router system - the default and uneditable setting should not have various protocols blocked. Very glad I didn’t wait and went with another system now.
