Ffebles
Dec 12, 2020Tutor
Connecting Nighthawk c7000 & Orbi mesh
My husband and I both work from home. We want to put my husband’s office down in the basement and my office upstairs. His system requires he be hard wires to a router. What is the best way to connect our C7000 and the Orbi system? I was thinking of creating two networks, one for his work system and have him hard wired to the C7000. Then have the Orbi manage the rest via WiFi with one Orbi upstairs and the other in the basement. Is there a better way to manage this? Will the WiFi work between the floors without losing speed integrity? I purchased the Orbi Wi-Fi 5GHz
it is compatible but uses the slower 866mbps backhaul versus the 50 series has a 1733mbps backhaul. Makes a little difference for peak wired speeds or if there's multiple wireless devices simultaneously using it. I've used both and never had an issue with the RBS40V in comparisons to my 50 series devices. You can always swap the rbs40v for the rbs50 satellite if the office is needing the faster backhaul.
Which orbi did you buy? (model)
What is your home made of and how big is it? certain materials block wifi so its tough to say "yes, it'll work" based off your info.
You have several options when it comes to setup. If you want to retain the C7000 then to prevent a double nat, you'd want to put the orbi in access point mode. This prevents running 2 routers in router mode on 1 network.
https://kb.netgear.com/30186/What-is-Double-NAT
https://kb.netgear.com/000061927/What-is-the-difference-between-router-mode-and-AP-mode
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
- plemansGuru - Experienced Useralso, make sure you have the c7000 and the orbi on different wireless channels to prevent interference
- FfeblesTutorI bought the RBK50. The house is wood frame and the flooring above the basement appears to be mainly wood. The upstairs is roughly 1700 square ft and the basement about 800.
If I put the Orbi in access point mode and the c7000 does the routing am I going to lose some of the speed the Orbi provided? We have 1G FO to the house.
Thank you for your help!- plemansGuru - Experienced User
If I put the Orbi in access point mode and the c7000 does the routing am I going to lose some of the speed the Orbi provided? We have 1G FO to the house.Do you have fibre? Is the C7000 currently working with it?
In ap mode, the orbi shouldn't loose any speed. It just relies on the C7000 to act as the router. So anything that was working before, should work. Same with vpn. If you're using a vpn on your c7000, it'll still work with the orbi in AP mode.
- FfeblesTutorI was just reading one of the links, difference between access point & router mode and it said that routers allow VPN. If I set up the Orbi in AP mode and I connect to it via WiFi will my VPN not work or will it just route the BPN connection through the Im router? I have to use VPN for work.
