Perege
Dec 11, 2021Star
Firmware update failes on satellites
Hi all.
I have downloaded the firmware 1.1.6.122 for my MK63 system.
The instructions says that I have to start with the satellites first.
But I get the message:
This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product.
Whats wrong???
- Your picture shows you're trying to update the satellite firmware to the router. Not to the satellite
did you extract the file prior to trying to upload it?
https://www.netgear.com/support/product/mk63.aspx
Yes. To CHK-file.
Also one of the files is MS and one is MR.
The MR is for the router. The MS is for the satellite.
I Know.
Doesn't Work. 😥
