jphensleyjr's avatar
jphensleyjr
How to configure EasyMesh devices to work with NightHawk mesh router
I see that the NightHawk Mesh routers support EasyMesh.  How do you add an EasyMesh device to the mesh?  I have tried putting the device in pairing mode using the add satellite as though it were a NightHawk satellite, but that does not work.  Thanks for any assistance that you can provide.
  • plemans's avatar
    Jun 05, 2023
    might be cheaper to just add another satellite. I think the MS60 and MS80 are both compatible with it.
  • plemans's avatar
    What router do you have?
    the only one I know that potentially had it was the MK series but I'm not sure if it was fully part of the EasyMesh standard.
      • plemans's avatar
        Are you trying to pair the satellites?
        You could try hardwiring them in and syncing them.
        I've seen that method work quite a few times
