Brendajackson12's avatar
Apr 09, 2023
I switched to Starlink for my internet. It works fine in my house but signal can’t get to garage.
Switched to Starlink as I live in remote are of Oregon.  Works fine in my house but my garage can’t get signal.  It is about 15 feet away.  What can I do to boost signal so I can use it in my studio in the garage?  If I hold my IPad by the window I can get signal.   What can I do?  Not very tech savvyThanks?
  • michaelkenward's avatar
    michaelkenward
    Apr 10, 2023
    Brendajackson12 wrote:
    I have. Nighthawk mesh system that I used with last IP but can’t figure out how to attach to Starlink modem.
    What's the Starlink modem.
    Some satellite thing out of Star Wars?
    As plemans says, no reason why the Nighthawk mesh system – which one? – shouldn't work with it.
    That sounds easier if the two 70 yo woman
    Youth! Streets ahead of you.
  • plemans's avatar
    You have a couple options that I'd recommend trying.
    1. (what I'd consider the best) is to run an ethernet wire between the 2 and use a mesh system so the satellite is in the garage and hardwired in.
    2. If you get full service in the window, you could use a mesh system and put a satellite in that window to use.
    3. you could try putting a wireless extender in the window of the garage. I'm partial to the triband extenders as they have a dedicated backhaul between router----extender.
      michaelkenward
      Brendajackson12 might like to consider option 4, if the mains circuit accepts it, is Powerline Ethernet.
      If the garage is on the same mains circuit as the house, and doesn't have a separate electrical circuit with lots of fuse boxes and isolators, you can turn the main into a fake LAN connection.
      But option 1 beats everything else.
      • Brendajackson12's avatar
        Brendajackson12
        Tutor
        That sounds easier if the two 70 yo woman without a lit if tech expertise. Is there a link you could share as to how to accomplish this.
        I have. Nighthawk mesh system that I used with last IP but can’t figure out how to attach to Starlink modem. I just need simple if that is possible. Thank you
