BrollAmerican
May 24, 2021Guide
Is the AX4300 Mesh compatible?
I have the Nighthawk Mesh 6 system and then the router started losing connection with the modem. After some testing, I determined the modem was fine, so the issue was with the router.
I went to Costco and bought the Nighthawk RAX45 / AX4300. My thought was it was a better stand alone wifi router, but since it was part of the Nighthawk series that I could also possibly power the satellites from my previous system.
This doesn't appear to be the case however. Can someone confirm or deny?
What actual mesh system did you have?
The RAX isn't a mesh router. So it doen't integrate with the full mesh systems.
It can be use in conjunction to them but not integrateed.
I have the MK63-100NAS Mesh system. The router portion seems shot, but are the satellites usable with the RAX45 router?
BrollAmerican wrote:
I have the MK63-100NAS Mesh system. The router portion seems shot....
What does that mean? What have you tried to fix it?
What is the modem in front of it?
...but are the satellites usable with the RAX45 router?
Unlikely, but that's a question best asked in the right place.
