petercreate's avatar
Oct 25, 2022
Mesh Mr60 router doesn't work and cannot be updated with the firmware
Hi,
I've tried reset and other reset methods I can find. Also, I tried the method introduced here, https://kb.netgear.com/000064624/How-do-I-upload-firmware-to-my-NETGEAR-router-using-TFTP-on-Apple-macOS . The last msg on the terminal is "Transfer timed out". I tried it times and get the same result.
It seems that the new firmware cannot be uploaded to the router.
Regards, Peter
I posted the information from the Mac OS terminal here,
Last login: Tue Oct 25 11:32:10 on ttys000
(base) jx@jx-MacBook-Air ~ % cd /Users/jx/Desktop/MR60-V1.1.7.132_2.0.64
(base) jx@jx-MacBook-Air MR60-V1.1.7.132_2.0.64 % tftp 192.168.1.1
tftp> binary
tftp> put MR60-V1.1.7.132_2.0.64.chk
Transfer timed out.
tftp>
  • plemans's avatar
    Oct 25, 2022
    Glad you got it figured out 🙂
    Might mark it solved so others aren't still trying to fix it
  • plemans's avatar
    what firmware version are you on?
    Is the router working and it just won't update its firmware?
    • petercreate's avatar
      petercreate
      Tutor
      Hi Plemans, thank you for your reply. It's working well now after a successful updating the firmware. Previously I connected the router via its Internet sock instead of the Ethernet sock, which was the reason the updating didn't work.
      • plemans's avatar
