akoz's avatar
akoz
Tutor
Jun 26, 2024
Mesh System Won't Broadcast SSID during setup.
Hi! Any help is appreciated.
Router: CAX30
Mesh System: MK63S
Internet works fine from the router, but across the house where my desktop is, it's awful, hence the mesh system. But after powering on the mesh system for initial setup, the app tells me to connect to the mesh's SSID, which doesn't broadcast. My router's regular SSID broadcasts, though.
Here are my steps:
- Reboot everything (I've previously factory reset both the router and mesh system, no fix).
- Open Nighthawk android app, click set up mesh system. Scan the QR code, place both satellites, wait.
- The app either then tells me the app doesn't support this router and to go to routerlogin.net (can't find how to set up a mesh system there) or it continues to the next step and tells me to connect to the mesh system's SSID.
- I open wifi, it's not there. And then a deadend.
In routerlogin.net, every setting I can find says it's broadcasting SSID. It's just the extender that isn't broadcasting/working.
  • plemans's avatar
    Try this. Disconnect the MK system from the CAX. Reset the MK system again by pushing and holding reset for up to 15 seconds while powered on. Then during the install of the MK system, connect a pc/laptop to it for setup. After going through setup (use a different ssid from CAX), make sure to put it in access point mode and have the wifi on different channels from the MK system to the CAX system. Once that's done and its in AP mode, then hardwire it into the CAX
    • akoz's avatar
      akoz
      Tutor
      Thanks so much for the reply. None of the devices I own have an Ethernet port. Any workaround for that?
    • akoz's avatar
      akoz
      Tutor
      I have hard reset the mesh, plugged it into the router, but when I go to routerlogin.net, there is nothing about setting up a mesh system. I've searched in every nook and cranny.
      • plemans's avatar
        disconnect the MK63 from the CAX. when its connected, its in a double nat with 2x routers running. the 2nd one needs to be in access point mode. So disconnect i from the cax, try using the routerlogin or its IP address then. go through setup and put it in AP mode before connecting it to the CAX.
