MarkHalley7
Mar 22, 2022Tutor
Mesh won’t load websites on iOS
We have a Mesh MR60 (router firmware v1.1.6.122) getting 600MBPS speeds to the house via cable (connected to a CM1100 modem). iPhones on iOS 15.3.1 will frequently not be able to load webpages when on the Mesh wifi, but switching to cell service instantly load those same pages. What’s up with the NETGEAR wifi service?
1. do you have IPv6 enabled?
2. is random mac/private IP enabled on the iOS devices? (try disabling it)
Thanks, plemans, for the reply. I tried turning-off the Private IP, but there was no difference in the iPhone behavior. And I'm not techy enough to know how to turn-off IPv6, but initial research online says that may not be a good option to take.
Any other thoughts? Thank you!
I meant to make sure ipv6 enabled. Its disabled by default.
Did you try going into the iphone and forgetting the network settings and reconnecting them?
