Vpatel803's avatar
Vpatel803
Follower
Oct 30, 2020
MK63 & Chromecast
Recently setup Nighthawk MK63 Wifi 6 Mesh system. Living Room chromecast setup perfectly and connects to the main router since that is also in the living room.
Problem is our upstairs chromecast is closer to the access point and so will not complete set up. Upon setup Google says setup is complete but can not connect and suggestions are to disable ap isolation. Only way I got it to setup properly for a short time period was to disconnect all access points and have it setup/connect to the main router but then once I plug in my access points the chromecast loses the ability to cast anything. Any work around for this?
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi Vpatel803,
    If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
    https://www.netgear.com/support/contact.aspx
    Christian
