schumaku's avatar
schumaku
MR60 DHCP IP-MAC Address Reservation
MR60 Firmware Version 1.1.7.134_2.0.65
Appears the Address Reservation "feature" is at least partially broken.
When going to the LAN Setup, the Address Reservation table is supposed to be shown ... hoiwever, it does not:
However, when using the [Add] button (on the above view!), the Address Reservation table does show up:
QA wa obviously on a holiday or watching some football, baseball, or icehockey game. Oh well ... remains the formal question: How shall we reports bugs here?
    • FURRYe38's avatar
      Checking my MR60 and MR70,
      I'm seeing the IP addressed reserved devices being displayed on the LAN Setup page: MS Edge browser
      • schumaku's avatar
        schumaku
        Negative. Exactly the same behavior for:
        Firefox 122.0.1 (64-bit) on Windows 11
        Chrome Version 121.0.6167.185 (Offizieller Build) (64-Bit) on Windows 11
        Edge  Version 121.0.2277.128 (Offizielles Build) (64-Bit) on Windows 11
        ...no obvious errors on the console, except of a "Page Layout many be unexpected due to Quirks Mode" warning all over:
        Same rendering result on Chrome, Chrome Beta, Firefox, Firefox Beta on all my Android devices, too. Back to the sender....
  • FURRYe38's avatar
    Ok, MS Edge was on Windows 11 Edge Version 121.0.2277.112. I just saw it updated to v.128. I'll check my MRs again after work.
    • schumaku's avatar
      schumaku
      Hard to imagine it's just about the very latest Edge only -:I see the problem since having deployed the MK63S list here to my playground initially, could be caused by the few IP-MAC reservation I have in place, too.
      DHCP Address range is 192.168.50.2 ... .254 and the table of the (working reservations) is in your PM inbox soon.
      I've expected to operate it on a dedicated VLAN in my lab, but found it does fail miserably on the LAN and it does bring down even more.... Oh well, consumer stuff 8-/
      • schumaku's avatar
        schumaku
        New "behavior":
        [Add] shows the table,
        [Edit] does error out and return to an empty list.
        Originally, I had reservations for two more addresses on the list: Two of the satellites, which I had renamed to MS60-1 and MS60-2 in the meantime.
  • FURRYe38's avatar
    Got home and check MS Edge, It had updated to v.128.
    Logged into my MR60.
    Showing attached devices on LAN Setup page:
    Access Controls:
    I see a couple of Fraggle attacks however this may have been my Galaxy pad conencting to the MR with it's WIFI Randomizer enabled. I had then disabled it and it reconnected to show real host name of the device:
