Robyvelocity
Jun 26, 2021Aspirant
MR60 port forwarding conflict
MR60 doens't shown the port forwarding rules. I've already updated the MR to the last version V1.0.6.110_2.0.49. I've also asked to the support to help me without success. The only solution provided...
- Nov 02, 2021
Have you opened a support ticket with NG about this?
Have you tired v1.0.6.116 version of FW?
michaelkenward
Jun 27, 2021Guru - Experienced User
Robyvelocity wrote:
How can I solve the problem only "reset the device" ? This is just a temporary solution which I'm not sure that solve the problem.
What makes you say that? It isn't true.
A reset takes you back to square one and gets you to set the thing up from scratch. How is that temporary?
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so there may be useful responses here, but your MR60 is a Mesh device with very different wifi technology, so you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Mesh System - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Robyvelocity
Jul 11, 2021Aspirant
Hello, and thanks for your reply.
Have you moved my issue in the right position?
I'm still having the same problem, and now it's urget to solve it.
And more, I'm not able to post a new message becasue the "labels" is required, but the label list doens't uppear.
Thanks.
- antinodeJul 11, 2021Guru
> MR60 doens't shown the port forwarding rules. [...]
When you do _what_, exactly? Are you just looking, or trying to add
a new port-forwarding rule, or what, exactly? How, exactly?> [...] I've already updated the MR to the last version
> V1.0.6.110_2.0.49.Not (now) the latest. Have you tried any others?
> [...] The only solution provided was: "reset the device". [...]
Did you try it?
> [...] which I'm not sure that solve the problem.
I'm not sure that it will solve the problem, either. But I can think
of one sure way to find out.> [...] the port forwarding rules. [...]
The non-psychics in your audience can't see how you configured your
router, including the port-forwarding rules. Did you leave UPnP
enabled?- durag5Nov 02, 2021Aspirant
Is this ever going to be fixed? This has been an ongoing issue over a year now. There are many posts in the forum about this issue as you can see below. The MR60 has been a nightmare with bugs. You even pulled firmware off the site it was so bad.
https://community.netgear.com/t5/Nighthawk-Mesh-System/MR60-port-forwarding-conflict/td-p/2109947
https://community.netgear.com/t5/Nighthawk-Mesh-System/MR60-MS60-Port-Forwarding/td-p/2117683
- FURRYe38Nov 02, 2021Guru - Experienced User
