Robyvelocity
Jun 26, 2021Aspirant
MR60 port forwarding conflict
MR60 doens't shown the port forwarding rules. I've already updated the MR to the last version V1.0.6.110_2.0.49. I've also asked to the support to help me without success. The only solution provided...
- Nov 02, 2021
Have you opened a support ticket with NG about this?
Have you tired v1.0.6.116 version of FW?
Robyvelocity
Jul 11, 2021Aspirant
Hello, and thanks for your reply.
Have you moved my issue in the right position?
I'm still having the same problem, and now it's urget to solve it.
And more, I'm not able to post a new message becasue the "labels" is required, but the label list doens't uppear.
Thanks.
antinode
Jul 11, 2021Guru
> MR60 doens't shown the port forwarding rules. [...]
When you do _what_, exactly? Are you just looking, or trying to add
a new port-forwarding rule, or what, exactly? How, exactly?
> [...] I've already updated the MR to the last version
> V1.0.6.110_2.0.49.
Not (now) the latest. Have you tried any others?
> [...] The only solution provided was: "reset the device". [...]
Did you try it?
> [...] which I'm not sure that solve the problem.
I'm not sure that it will solve the problem, either. But I can think
of one sure way to find out.
> [...] the port forwarding rules. [...]
The non-psychics in your audience can't see how you configured your
router, including the port-forwarding rules. Did you leave UPnP
enabled?
- durag5Nov 02, 2021Aspirant
Is this ever going to be fixed? This has been an ongoing issue over a year now. There are many posts in the forum about this issue as you can see below. The MR60 has been a nightmare with bugs. You even pulled firmware off the site it was so bad.
https://community.netgear.com/t5/Nighthawk-Mesh-System/MR60-port-forwarding-conflict/td-p/2109947
https://community.netgear.com/t5/Nighthawk-Mesh-System/MR60-MS60-Port-Forwarding/td-p/2117683
- FURRYe38Nov 02, 2021Guru - Experienced User
- durag5Nov 02, 2021AspirantI called in awhile ago about this and other issues. I'm sure the ticket isn't open now. I don't know how to make a new ticket as I just found out my hardware 1 day out of warranty. I called again today with no answer. I have the newest firmware and I did a 30-30-30 reset. It's still an ongoing issue that's never been fixed.
