kickns
Jan 06, 2022Aspirant
MR60 wireless devices connected to router can't ping each other or see shared directories
MR60 router firmware version V1.0.6.116 Two MS60 satellites firmware version V1.0.6.116 Here is the issue. All of my devices have Internet access and performance seems to be fine. However, two...
- Jan 06, 2022
turning off Armor and then turning off the MR60 and MS60s worked. I am going to turn Armor back on and live with the issue for now. Thanks.
Jan 06, 2022Guru - Experienced User
Does this happen over wireless and wired connections?
Is Armor enabled by chance?
There is a more recent FW version that you might try:
Netgear has set up a community forum specifically for the NightHawk MESH products for additional help and information:
https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-system
Thank you.
kickns
Thanks for the feedback. It is only wireless devices that I am having an issue with. I have one wired device (my apple Time Capsule where my backups go) but all of the Macs seem to be able to see it to perform backups.
My route does not believe that there are any FW updates available. I know that I can update manually. How safe is it to upload that new version?
Thanks again.
- FURRYe38Jan 06, 2022Guru - Experienced User
Using a wired PC and web browser connected to the MR is recommended. First update the MS then MR lastly.
Did you turn OFF the MR and MS for 1 minute then back ON after disabling Armor?
- kicknsJan 06, 2022Aspirant
I will try disabling ARMOR and turning off the MR and MS at an opportune moment.
Right now my workaround is to hook the two systems up via Ethernet. Given the low need for sharing between the two systems, that is probably good enough at this point. Will consider the updated firmware approach. Thanks.
