kickns
Jan 06, 2022Aspirant
MR60 wireless devices connected to router can't ping each other or see shared directories
MR60 router firmware version V1.0.6.116 Two MS60 satellites firmware version V1.0.6.116 Here is the issue. All of my devices have Internet access and performance seems to be fine. However, two...
- Jan 06, 2022
turning off Armor and then turning off the MR60 and MS60s worked. I am going to turn Armor back on and live with the issue for now. Thanks.
Jan 06, 2022Guru - Experienced User
Does this happen over wireless and wired connections?
Is Armor enabled by chance?
There is a more recent FW version that you might try:
Netgear has set up a community forum specifically for the NightHawk MESH products for additional help and information:
https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-system
Thank you.
kickns
turning off Armor made no difference. This is a minor annoyance at this time and don't want to brick my system by doing a manual firmware upload at this time.
