trnd7's avatar
trnd7
MR70 router no longer able to access the Internet
Yesterday my MR70 Mesh router started displaying the amber light. I've been trying to troubleshoot this for hours but nothing is working so I'm wondering if anyone has any idea on what to try.
Here's some info:
- Comcast is my ISP
- I'm using a CAX30 modem (I disabled its Wireless) and all wired connections to it work
- I had an MR70 router with two satellites; the connection between those and the devices seem to work, but the router can't connect to the Internet; in the Nighthawk app it had an Internet address of 0.0.0.0 but when I look at my modem settings in routerlogin.net I see it being assigned an IP address
Here are the things I tried:
- Reboot modem and router, both via the Nighthawk app and by unplugging the power
- Check firmware is up-to-date
- Connected my desktop PC directly to the router
- Factory-reset the router, re-installing it via the app
Bonus question: in that configuration, routerlogin.net redirects automatically to the modem. How can I then connect to the router? (I tried routerlogin.com 192.168.0.1 192.168.1.1 192.168.100.1 and they're all the same)
  • FURRYe38's avatar
    Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
    https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
    3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
    https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
    https://kb.netgear.com/000061927/What-is-the-difference-between-router-mode-and-AP-mode
    Try #1 first.
    Power off for 1 minute then back ON with the ISP modem and router.
    Turn off and unplug modem.
    Turn on computers and rest of network.
    • trnd7's avatar
      trnd7
      Thank you for the quick reply! I read conflicting information about the CAX30 regarding modem or bridge mode, but I found a "router mode" in the admin settings and it seems to be doing the same thing. Unfortunately that didn't make the MR70 router be able to connect. So I'm looking into option #2 now.
      EDIT: how come that this problem just happened yesterday after this network configuration worked for months? Is it possible that it was caused by an ISP change, since they told me that they are doing some work on their network at some point?
      • FURRYe38's avatar
        trnd7 wrote:
        Thank you for the quick reply! I read conflicting information about the CAX30 regarding modem or bridge mode, but I found a "router mode" in the admin settings and it seems to be doing the same thing. <Router mode is a Yes or No settings option so if you select Yes, the modem will be in router mode. If you select No, this sets the modem to modem only mode.
        EDIT: how come that this problem just happened yesterday after this network configuration worked for months? Is it possible that it was caused by an ISP change, since they told me that they are doing some work on their network at some point? <Possible FW issue on the CAX30. What version of FW is loaded on the CAX30?
        Also when the CAX30 and MR are in router modes this creates a conflict between the two as by default they both use 192.168.1.1 as a IP address start. The MR should detect this and should change to 10.x.x.x though. Or you can manually change the MR to something else. I use 192.168.0.1 on my routers.
        Also be sure to power cycle the MR70 OFF then back ON when changing modes on the CAX30.
