steveof2620's avatar
Nov 12, 2021
MS60 Satellite - No connected device found
Hello,
I am wondering if anyone can help me understand why none of my devices connect to the Mesh Satellites. I have two satellites connected to my MR60 Mesh system, both are found in the phone app and display as connected.
However, when I select teh "Devices" tab on both it displays "No Connected Device Found". Is there a trick to getting devices to connect to the satellites? Why are no devices listed as being connected to the satellites dispite being, in some cases, right next them?
I love to understand why. Thanks for any tips.
  • I have reset one of my satelites and unplugged the ethernet cable. Yet the router insists it up and running with a wired connection. I rename the satelite in the app... of course it doesn't save the name.
    I can't say I am terribly impressed with this system. What I can say is this has been a very disapointing purchase.
    • plemans's avatar
      Devices roam between the satellites/router based on their own roaming protocol. Its not the router/satellite that moves them.
      what you can do to ensure the best chances of roaming?
      1. make sure the satellite/router are at least 30 ft apart
      2. Check your home size. If the home isn't big enough, the devices will default to the router. In this case, you can try turning down the broadcast power a bit and see if that encourages roaming.
      3. try turning the wifi on/off on the device you're using. If it defaulted to the router and the distance isn't that great, a reconnect might have it connecting to the satellites.
      • I have never seen one device, not a single one, ever attach itself to either of the two satellites. Should they go to landfill?
  • FURRYe38's avatar
    Also try turning down the power output of the MRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
  • FURRYe38's avatar
    Any progress on this?
    steveof2620 wrote:
    Hello,
    • RogEnk's avatar
      RogEnk
      Initiate
      Have come to the conclusion after many years of being a loyal customer for 10+ years of Netgear that I will never buy another one of their products.
      Over priced at the outset and mandatory ‘extended’ support in order to submit a warranty claim adds insult to injury.
      My Nighthawk + 3 satellites threw a wobbly 17 days after warranty expired, one satellite simply will no longer sync and has the pale blue light flashing continuously, the other two go solid blue but no devices connected. With a 4000 square foot smart home with 80 devices including switches and smart media devices this is unacceptable support, and no I won’t be paying to get support for a product that a company the likes of Netgear should be proud to stand behind, Asus have a much better rep. Anything Netgear is simply disappointing and extremely overpriced considering that gouging 90 day support window. $300 paper weights… oh and the ‘armor’ renewal that the router cannot recognize? Also a rip off, true my devices are protected but the gateway to my home is not because it is unable to recognize I renewed?!
      Shame on you Netgear, and even more shame that official representation on your community is as rare as rocking horse manure.
      Oh. FYI I am an IT professional with 30+ years experience including Cisco and MS certification. Your support is non-existent and I advise all buyers stay away.
