acayci's avatar
acayci
Tutor
May 14, 2026
NetGear MR60 Router - WiFi Connectivity Issue between two computers
Hello,
I have a MacBook with WiFi  to connect to Internet.  I have another computer (Jetson) that is also connected to Internet using Wifi.  They both are on 5 GHz. channel.   I cannot ping from my MacBook to Jetson and vice versa.    I can confirm both are in Access Control -> Security Allowed.  Is there a Router configuration that I should be paying attention?
Thank you,
Mustafa
  • I turned off Access Control completely.  I tested ssh.  I was able to connect to Jetson.
    Mustafa
    • StephenB's avatar
      I'm glad you found a workaround.
  • Hi samuraineet​
    I am sorry that I am replying to this very old post.  However I am seeing the same issue in my network.  I use MR60 and MS60.  Both MacBook and Ubuntu linux machines are on the WiFi.  They cannot see each other.  They can individually ping the router IP,  or even the Internet but not each other.   Do you have any suggestions that I should look at?  Thank you.
    Mustafa
  • Hi StephenB​
    acayci wrote:
    Now I am able to ping Jetson from my MacBook.  I am also able to ssh.
    I had to restart the Jetson and logged back in from the monitor to Jetson.  I cannot ping to Jetson now from MacBook.  I guess I did not resolve my earlier issue.
    Just to add additional information ...  I have now only one satellite and both MacBook and Jetson are connected to that.
    Mustafa
  • Hello StephenB​
    Is this a continuation of your older discussion thread?
    It is the same setup.  The VPN service is still there.  However now I am trying to connect the Jetson from my MacBook with WiFi because the Jetson is installed on the drone and there I need to be able to communicate with it in my back deck.
    If you are still running V1.1.7.134_2.0.65.2 firmware, then start by updating it.
    https://kb.netgear.com/000070298/MR60-MS60-Firmware-Version-1-1-8-142
    I upgraded the firmware as mine was V1.1.7.134_2.0.65
    Now somewhat peculiar issue,  one of the satellites wasn't able to come back online.  It is having white blinking light.
    Mustafa
    • StephenB's avatar
      Great.
      What have you tried (if anything) to resolve it?
  • StephenB's avatar
    1. What firmware is the MR60 running?
    2. Can either machine ping the MR60 LAN address?
    3. Have you made sure that the Mac firewall doesn't have "Stealth mode" enabled?  That would block Jetson attempts to ping the Mac (but not vice-versa).
    4. Are both machines connected to the same MR60 mesh element?
    5. Are both machines getting their IP addresses with DHCP?
    FWIW, there is an old unresolved discussion thread here that is related:
    • https://community.netgear.com/discussions/en-home-nighthawk-mesh-system/cannot-ping-the-device-in-same-network-mr60/2015192
    • https://kb.netgear.com/000070298/MR60-MS60-Firmware-Version-1-1-8-142
    FURRYe38 wrote:
    What platform is the "Jetson" computer?
    Jetson is an AI platform made by NVIDIA.  They run Jetson Linux (formerly called Linux for Tegra).  This is derived from Ubuntu.
  • FURRYe38's avatar
    What platform is the "Jetson" computer? Windows? Linux?
    Be sure any firewalls or security apps are disabled on these PCs that could be blocking.
    Armor or Smart Parental controls enabled by chance on the MR?
