ketachicken
May 10, 2022Aspirant
Netgear Nighthawk MK models can only access Google/Facebook, but not for other sites.
I have been using the MK62 since 2020. This problem start popping up when I switched my service provider this month. Occasionally, I will lose access to all websites, except for Facebook, Google,...
May 10, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- ketachickenMay 10, 2022Aspirant
My Firmware version is V1.1.6.122_2.0.58.
ONT model no. is G-240G-E by Nokia. It is connected to another router provided by local Internet Service Provider (confirmed that this router has no connection issues when the situation occurs).
Did several resets since last update.
- plemansMay 10, 2022Guru - Experienced User
so you're going the nokia---->other router-----MK nighthawk?
That can cause a double nat and issues.
why are you using the other router?
Is it in passthrough/modem only mode?
Or have you put the MK nighthawks iP address into the other routers dmz?
