ketachicken
May 10, 2022Aspirant
Netgear Nighthawk MK models can only access Google/Facebook, but not for other sites.
I have been using the MK62 since 2020. This problem start popping up when I switched my service provider this month. Occasionally, I will lose access to all websites, except for Facebook, Google,...
May 10, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
ketachicken
My Firmware version is V1.1.6.122_2.0.58.
ONT model no. is G-240G-E by Nokia. It is connected to another router provided by local Internet Service Provider (confirmed that this router has no connection issues when the situation occurs).
Did several resets since last update.
- plemansMay 10, 2022Guru - Experienced User
so you're going the nokia---->other router-----MK nighthawk?
That can cause a double nat and issues.
why are you using the other router?
Is it in passthrough/modem only mode?
Or have you put the MK nighthawks iP address into the other routers dmz?
