JRStone
Nov 20, 2022Aspirant
NEW - NIGHTHAWK MESH WIFI 6 ROUTER #MR60
Hello fellow Computer geeks, Bought this Router about 1.5 years ago. Been trying to update the Firmware on my router today using Netgear's web site and downloads. Using the "Manual Update" option. ...
Nov 21, 2022Guru - Experienced User
What error are you getting when you try to update the firmware? This is kind of key as you don't tell us where its failing in the process.
We usually recommend updating the satellites first and then the router.
When you download the file, are you extracting it first and then following the manual update process?
- JRStoneDec 02, 2022Aspirant
HI and thank you for your reply.
I updated the firm ware "V1.0.4.96" the Satellite first with the "current version for MS60, which is V1.1.7.132" Then I went on and updated the Firmware on the router with MR60, which is also V1.1.7.132. When I check the router status it shows the new Firmware was in fact updated on the router and on one of the satellites. However the second satellite still has the old firmware version. I tried updating the second satellite with the MS60 firmware "V1.0.4.96" but nothing changed. I see the update bar progress and I get the message to wait until the update is complete. Also under router status is a "reboot" button that is colored red" but I cannot execute that button. I DON'T KNOW WHAT ELSE I CAN DO.......I appreciate your help!!
- FURRYe38Dec 02, 2022Guru - Experienced User
Do you happen to know what version of FW is on this 2nd MS? if you do, you may need to downgrade the MR back to same version thats on the MS. THEN, try to update the MS to more current versions of FW, If you can do this then update the MR lastly. Be sure to up MS always first before updating the MR.
YES,
The old Version of firm ware is V1.0.4.96.
I will try to change back to the old version tomorrow and the update the satellite and eventually the Router. Thanks for the suggestion.
Do I need to do something different when upgrading the satellites?
Should the two satellites update together?
