bulldog00's avatar
bulldog00
Apprentice
Nov 30, 2022
Night Hawk MR80 Slow WiFi
I am experiencing the same issue with my MR80/MS80 setup.  I did not have this issue previous to the current FW push of 1.1.7.xx.
I have tried all kinds of troubleshooting, factory resets, and even have the MS80's wired backhaul.  I did not have this issue on the satellites previously and after all troubleshooting, i believe the issue is FW related.  Unfortunately, Netgear doesnt allow users to disable "auto updates" for the firmware on the MR80 series.
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR📡 and MS🛰️ to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products đź›°
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    What speeds do you see at the MR when the MS are turned OFF?
    What wireless devices are you testing with?
    Do wired speeds reporting same results?
    • bulldog00's avatar
      bulldog00
      Apprentice
      The Latest available- 1.1.7.12
      Cannot disable automatic updates for the FW.
      Netgear CM1100; Xfinity
      Quality CAT6 cable is used between Modem and NG.
      2300 SQ FT
      What is the distance between the router and satelite
      30ft. Issue did not occur with previous firmware version.
      Channel 1 for 2.4
      Channel 44 for 5
      Have tried alternate channels and scanned for interference.  No interference.
      MR Speeds are consistently around 680-700mbs of wireless; hardwired is around 940mbps.
      I have a plethora of devices being an IT professional,
      Wired speeds are noticeable faster.
      Also worth Noting that through the netgear application, checking the device that is connected to the MS, even though the device is connected to the 5GHz band, the link rate is significantly low.  Currently the link rate of a device connected is 211Mbps.
      • FURRYe38's avatar
        Can you post screen captures of the MS connection rates and devices connected to the MS.
        Did you do a full factory reset and both MS and MR and setup from scratch?
      bulldog00
      Apprentice
      It doesn’t detail anything in the bug fixes to indicate it resolved that particular issue. And it’s kind of a pain to keep jumping back on FW to test; I’d rather netgear just fix the issue or test themselves rather than me playing scrabble to find a FW that works appropriately.
      • FURRYe38's avatar
        So NG is recommending you update to newer FW. NG isn't seeing issues in this regards to slow wifi, however mentioned there is improvements with in the FW and a fix in regards to channel width. So this may have been one issue. They also suggest placement and distances between the MR and MS should be looked at. Maybe move the MS a bit closer to the MR?
        Up to you though.
