87national
Jan 08, 2022Aspirant
Nighthawk AX3600 Tri-Band WiFi 6 Mesh System
It appears my router is t even a selection available as a model, I’m looking for information regarding connectivity issues with NETGEAR - Nighthawk AX3600 Tri-Band WiFi 6 Mesh System (3-Pack) or calle...
Jan 10, 2022Guru - Experienced User
87national wrote:
V1.1.6.6 when checking for updates it says it’s up to date as well.
Might review this:
https://community.netgear.com/t5/Nighthawk-Mesh-System/New-MK8x-series-MR80-MS80-FW-v1-1-6-10-Released/td-p/2168315/jump-to/first-unread-message
Arris S33 and xfinity is the ISP.
1800 sq. Ft.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR and MS📡 to begin with depending upon building materials when wirelessly connected.
Literally 5 feet and through a floor an 20 feet for the 2nd satellite. >This is too close for the 1st MS. 30 feet is starting distance. What happens if you turn OFF the 1st MS and leave the 2nd online.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-W... 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Channel 11 on 2.4Ghz and 48 on 5Ghz respectfully
2 neighbors on left and right. Do they have wifi and if so, can you see what channels they are using?
87national
Jan 14, 2022Aspirant
So I can’t get the firmware to update, but I unplugged the satellite closest to the router and spaced the other satellite a little further away. So far so good! Our phones haven’t dropped since doing it, and my wireless speed is soso. Speed test through Netgear shows 940Mb/s download and 40 Mb/s upload.
My Xbox is showing 41Mb/s download and 11Mb/s upload and a ping of 49ms.
- FURRYe38Jan 14, 2022Guru - Experienced User
Ok so maybe a MS placement and distance issue and maybe you don't need the other MS...See how this configuration works for you.
