mbbk's avatar
mbbk
Tutor
Feb 08, 2022
NightHawk Mesh WiFi 6 System AX1800 MK62
Hi All -
Looking for some assistance with a connectivity issue.  We have the NightHawk Mesh WiFi 6 System AX1800 MK62 since 10/2020 and was working great.  As of 1/21/2022 I can no longer connect my work laptop to the wifi through the router or ethernet connected to the router.  My laptop is a Windows Surface and I have been told that there is an known issue with NetGear routers connecting to Surface laptops.  Seems odd to me that it worked fine since 2020 and now there is an issue.  Any suggestions on how to resolve the laptop not picking up wireless or ethernet from the router.  It does work when I connect the ethernet to the back of the modem, however, the rest of the house is then off of wireless wifi and cannot work (we all work from home and I am the only person with issues).
Thank you!
  • plemans's avatar
    the surface is the only device with issues?
    What wireless chip is in it and what driver does that chip have installed?
    • mbbk's avatar
      mbbk
      Tutor
      Yes the surface is the only one having the issue.  It is a work provided laptop and I am unable of the wireless chip or what driver the chip has installed.  Any idea how I determine that?  I apologize but I am not a computer guru.......thanks!
      • plemans's avatar
        go to your device manager.
        then network adapters.
        That should display your list of adapters. Pick the wireless one (should have a model)
        right click on it--->properties--->driver
