Hammer5000's avatar
Hammer5000
Nighthawk MR 60 Mesh Satellite Connection issues
I just purchased and set up last night, one router and two satellites. Everything seems to be working properly, except nothing is connecting to the satellites, even my Amazon Fire Stick which is in the room with the satellite.
Everything is connected to the base unit.
  • plemans's avatar
    how far apart from the router is the satellites? 30 ft is recommended.
    Do they function properly if you hardwire a device to them?
    Reason I ask, is the router/satellites don't actually switch devices between them, its the devices own roaming protocol that devices which to connect to.
    • Hammer5000's avatar
      Hammer5000
      The satellite in the room with the Fire Stick is less than 30 feet, more like 18 feet from the router. Sounds like the satellites only engage if the router signal is not as strong as the satellite?
      I bought the mesh system because the Fire Stick occasionally struggled with my old router. Sounds like I don't need the mesh system. My house is only 1950 sq ft.
      • plemans's avatar
        It still can help with coverage having the satellites but just make sure they're far enough apart or devices don't roam as you'd expect.
  • It obviously isn't a great product if the satellite is between the router and me and it won't switch over to the closer one. I get 50 to 120mb/s on my laptop and mobile phone 10 feet from the satellite, and can get 400mb/s+ if I walk 20 feet to my room. Unfortunately, I can not move the satellite without running an ethernet cable across the living room to my TV.  Why can Netgear not enable the ability to block and unblock devices from connecting to the router or a satellite so that it connects to the one that will give the best speeds? It doesn't make sense. I've read so many forums with people experiencing the same thing. It should be made possible. Or at least mention in your that it doesn't help internet speeds in houses under 2000sq without putting them on opposite sides of the house.
    • Loverofsun7's avatar
      Loverofsun7
      Initiate
      Yes it is the worst Netgear product I have ever purchased and I always buy from this product. I bought this year in January and literally spends hours every month trying to reconnect it. I bought because it was supposed to automatically update and literally every month spent hours and hours trying to get it reconnected having to login to router.net work with some online person I’ve tried to get my money back I’ve tried to exchange it for another product we are absolutely done. I’ve tried to contact Netgear over and over and it wasn’t until I put a bad review on Best Buy that someone finally contacted me only to not resolve my issue here again I am without Internet for most of two weeks because I haven’t had time to spend hours and hours reconnecting. My husband is sick and tired of us not having wireless Internet and so am I! Since Netgear won’t help me we are going out to buy a new router today.
      • FURRYe38's avatar
        Any progress on this?
    • FURRYe38's avatar
      It's up to the connected devices it pick and choose where they connect too. Not the MESH system. It only provides the platform for devices to connect too.
      What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR and MS📡 to begin with depending upon building materials when wirelessly connected.
      Try turning down the power output of the MRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
  • I have only had this MR60 less than two weeks and the satellight stopped connecting. I am very disappointed with the customer service I am getting with netgear. I have a case open and not resolved. Don’t buy this system!!!
